EDIT: So you don't have to go to the end of the thread. Hopefully this will help someone. Especially if I am not wrong.
I found a pair of diodes in the gauge harness of my '72, located behind the brake warning light above the fuel gauge, Since I was rewiring for a triple gauge I wanted to know what they did. I have since figured it out. It is unique to the '72, since one diode was present earlier and then disappeared as another was added. Only the '72 has both. So I had to look at the '71 and the '73 diagrams to get a good answer. The '72 diagrams are blurry. So below is what I tracked down. Let me know all you engineers in the mist if I am on the correct track.
One of the most puzzling things to me is that Porsche often uses the transistor symbol on a relay when they don't want to tell you about what is inside. I now think that the transistor symbol means just a symbol for an NPN transistor. Overcomplicated that one, I did.
I also just realized that the system would prevent the seatbelt warning system from going into effect until the parking brake was released with an unbelted occupant. That now tells me why R3 is there and why a transistor.
Thanks everyone who chimed in, and if there are mistakes please correct them! END EDIT
I am trying to make the gauges on my six conversion easy to disconnect with only one or two plugs. Now I want to wire my triple gauge and that includes the brake light. I have brown wires with white stripes that appear to go to switches to ground:
The hand brake switch.
The master cylinder shuttle switch.
The wire to the brake reservoir switch that is activated by low fluid (not normally connected).
A wire out to the seat belt warning light.
I have a wire to the alternator blue with a diode. I think this turns the brake light on momentarily at start up.
Then there is an identical diode between the brake light and a brown and white striped wire. I am thinking this goes to the seatbelt light, but haven't traced it. What does the diode do, and how does the seat belt figure into this. I see it on a diagram, but cannot figure out what current the diode is meant to block.
Thanks folks!
