QUOTE(jimkelly @ Aug 18 2015, 01:27 PM)
for some reason my wipers do not function from controls on the column. so to pass inspection, I was thinking of wiring them just enough to get one speed.
which wires would make a circuit to run my wipers at one speed?
Jim did you check to see if the male pins coming from the switch are all there ?I found 2 of mine had pushed through the wire retainer,its a pain to fix but will get you going,just an idea.
