Hello all,
I need to buy a set of "over type" grease caps in good condition. Just to be clear these are for 911 boge struts going to be used for a conversion.
-There are two main types of these, ones that fit in the hub and ones that fit over the hub with an interference fit. I need the latter type.
-They should have a 58mm diameter and the shape should be wider at the opening than at the closed side.
Please let me know what you have. I will need pics on this as I recently purchased a set of the wrong caps.
Thanks,
Andrew
