QUOTE(Beakster @ Aug 19 2015, 11:09 AM)
I'm looking at a 914 today and I need to know where to look for the rust on a 914 .. The knowen areas like the Battary box (hell hole) and rockers .. But is there any special places .. pictures would also help .. Thanks guys
Everywhere. Seriously, EVERYWHERE. I learned the hard way. Scour every inch of metal you can see. Pull up carpets, remove rocker panels, look deep into every angle of the wheel wells, door jambs, longitudinals, engine compartment, rear trunk, front trunk, under the headlights, inside the doors, sail panels, floorpan, center tunnel, firewall, behind bumpers, rain gutters on front and rear trunks, engine mounts, trans mounts, suspension consoles, suspension mounting points, fenders...you get the picture. It ALL rusts. Spend as much time as the seller will let you scouring the car. And bring a bright flashlight.
