tach
Aug 20 2015, 12:48 PM
914 rear Sachs/Boge rubber shock stop bumper part number
8 in the picture. What equivalent to use, original's NLA?
If anyone can get me the a dimensional length and outside diameter of the original. I could probably just buy some generic shock stop material and trim to fit.
Thank you,
Aug 20 2015, 01:28 PM
Ask around and see who has an old set of shocks. Must be thousands. But I agree. It's nothing special so find something that works and you'll be good.
Mikey914
Aug 20 2015, 03:31 PM
I did procure a sample to do these at some point, but if they are available let me know.
914Sixer
Aug 20 2015, 03:55 PM
Mark, that is for the front shock not the rear. Lots of used front ones around. The rear is similar BUT it has a steel washer in the top of the rubber that came un-bonded and fell off.
Paragon Products has one made by Koni. Part number is Koni-70.34.53 Looks like it just floats on the shaft with no steel washer. Another option maybe one from the 996 or Boxster in the second picture.
Mikey914
Aug 20 2015, 04:31 PM
I'm confused. The drawing appears to be the rear the part I have looks like it may have been bonded to something. The tanish ones don't look familiar to me at all.
How can I tell if it's a front or rear as both drawings look similar?
914Sixer
Aug 20 2015, 04:54 PM
The drawing looks to me like it is showing the washer in the center of it. It fits on the bottom of the threaded part of the shock. I will look to see if I have the washer part of the piece that the rubber is molded into.
Olympic 914
Aug 20 2015, 05:12 PM
Don't know how this will work, but when I put my rear shock / springs together I just took some front rubber bumpers and using contact cement I glued them to the washer that was part of the original bumper on the rear shock assembly.
I figured that even if it came loose it would still be on the shaft and work the same as the Koni ones that just slide on.
