here is my recent butyl installation using Chinese glass
http://www.914world.com/bbs2/index.php?showtopic=235156the most delicate part of the operation is removing the trim. It is a time consuming project. The problem is that newer (younger aged installer) shop owners generally are well practiced in the art of applying urethane from a squeeze gun, rather than using a bead of butyl.
the old glass I removed had been glued in with urethane and there was a 12 inch section of A pillar trim that I had to cut out with an Xacto knife because of the urethane bleed over. The A pillar trim came out unscathed. I now realize my post here is at the higher end of time and complexity because it had been bedded with urethane. I also realize that for the installation of butyl, as long as the paint is dry and clean (as in the pic of the yellow 914 I posted from another club member) the old bead will hopefully come out in chunks, and you can use solvent to clean off the old bead. Then you will not need to grind off the old urethane and/or paint, and NOT need to apply the black "Frit" paint.
