QUOTE(RobW @ Aug 24 2015, 12:18 AM)
Time to check the oil lines. Should the fittings be really tight, and should tape be used in the threads?
How much oil capacity would a 2.4 with no front oil cooler take?
What type of breather line - type of hose runs from the oil tank to the top of the engine? Is this under pressure, and should it be clamped?
Thx
Make sure the hoses are fully supported when tightening,the oil cooler hose is the one to be really careful with,the coolers @ that point aren't very strong.
You can buy a tank breather hose from Pelican,I ordered the one for the 71 911T,its the correct type/size and only needs to be cut shorter,think I payed around $25.
