QUOTE(Stacks914 @ Aug 24 2015, 02:47 AM)
It's in the relay board behind the driver in the engine compartment. You'll see three or four small round relays in a staggered order on the left side. If you look at it from the back of the car it is the third one from the back. I just did this and mine turned out to be a faulty #14 wire coming in from the harness. Good luck!
thank you so much I am going out this morning to check this out.
stay tuned.. I will let ya know what is the outcome.
BTW: why did you change yours?
914luva
