After adding the Pertronix Ignitor 1 last night, I was having some clearance issues with the rotor and cap. So I searched the forums here and decided to start shaving a little off the bottom of my rotor to get everything seated properly.
My question is for the guys who have already shaved down their rotors for a Pertronix install. How much did you remove? I've already shaved off 1-2mm if I had to guess.
And a funny story - after the 2nd trip to the grinder, I reinstalled it and the car started right up and idled great. So I took it out for a short test drive. After about a mile it started to studder and loose power and by the time I got home it was struggling at all RPM's. Well - It turned out I hadn't fixed my clearance issue afterall, I had accidentally clamped the cap down without it being seated correctly so it was sitting higher than it normally would. I have a new cap and rotor on the way from Pelican. Just want to make sure I don't shave off too much.
BTW - I didn't need to use the spacer plate, I've also gapped the magnet and module to spec per the instructions. And the magnetic collar is fully seated, no hammer and socket needed. The car cranks real strong and I can smell fuel, but it's not starting.
