QUOTE(porschetub @ Aug 24 2015, 06:05 PM)
QUOTE(Gcthielen @ Aug 25 2015, 06:49 AM)
I am assembling my 1971 914-6 and can not figure out how to tighten the line in the center of the photo. It appears to be a pipe thread on either end...the right (tank side) is loose. can it be tightened by hand? special tool? The collar has no flats but rotates on the line itself.
Thanks!
George
Click to view attachment My first view I thought they were reusable fitting,but without the hexs they can't be,if they turn in place I would say the hose is toast as mentioned.
It will leak no question,I sourced my hoses and parts from Stoddard,they have a good selection of Cohline fittings and crimps @ the best prices.
The hose you will need should be sourced from the shop that can press the crimps on for you,another option is to buy from Porsche but I seem to remember some of them are NLA now.
The aluminum collars do not turn. The lines do not separate there. They only separate at the obvious threaded fittings at the tank and at the connection of the "cooler to tank" hose and the "tank to cooler" hose. These are named and numbered in the PET and on various websites. They are also diagramed on the Patrick Motorsport website. The lines are available from PMS. They are good quality, readily available and not expensive
If you tried to tighten the nut against the aluminum collar and it is now turning, it may leak there
