My 75 Alaska blue with white interior is a 7 out of 10.
It's a good project that is not complete.
The Good-
New paint (3 yrs old)
New interior, Carpet, seats, door cards, and I have the material to do the backpad, but haven't yet.
Euro tail lights in very good condition
new (ATE) master cylinder 19mm, rebuild front capilers
Custom one of a kind Blue WAS top
All new rubber
New tires
new 4 lug Fuchs (aftermarket)
new fuse panel with blade fuses
It can pass DEQ (and I will sell with fresh tags)
Dual webber 40's with webcam
Backdated bumpers with fog lights (craigs' pilot lights)
All turn signals work, brake lights work
Bumpers are in good shape, bumper tops in good shape. The front bumper is a 75, I can provide some tips, but they are not installed
New windshield trim, new front windshield.
The bad
-There's some body work that's not quite right in the passenger side front fender. -There's some bondo around the front turn signal. I have a replacement section I can include.
-It has 2 dual Webber 40's that were just rebuilt, sounds really good WOT, but it is cold blooded. There is some issues with the jetting / set up.
-There are some minor electrical gremlins. occasionally the signal light with blink (loose connection?). Drivers side marker light not powered.
-Main seal at fan needs to be replaced ( I can have done, but haven't yet).It has a seep that if you drive it for a few days you can see a few drips at the bottom of the housing. It will need to be replaced, I had hoped to do so this winter.
E brake cables need to be tightened
It's a good pretty solid car. The hell hole looks like it has been repaired, there is not ant rust at the jack point and I haven't found any metal that I can poke a screwdriver through. It seems sold enough, and I'll re survey it to verify. I had not intended to sell so I'll look again. The repair work looks solid enough I didn't dig into it.
Asking $13,500, as it's not perfect, but could be a $25k car with much less than the difference invested. I want to sell it at a fair price, but can't give it away. Figured I'd put it out there at a reasonable price, rather than start high and wait for the market to come to me.
I'll get more pictures posted late tomorrow.
The only reason I'm putting this up is because I have the opportunity to pick up an early 70 car that I'd like to build into a 6 clone. The wife has made it very clear that I've reached my capacity, and that if I want to get it I need to replace 2 cars. So Big red will be going up soon too, but I can take it home if I sell 1.
