Two things I noticed when changing my plugs to NGK Spark Plugs.
1) I noticed that when I went to put on the spark plug wires on to my new NGK pugs, the head of the plug is much larger then the old wire port? I also noticed the inner part of the spark plug is threaded, is there an adapter that screws in for smaller wire ports?
2) I also noticed while I had everything apart on of my spark plug wire ports was broken (the plastic end that connects to the spark plug)... So now I have to buy a new kit anyway...
- Do the NGK plugs have a certain head size I should look for in getting a new spark plug wire kit? Or just look for a "standard" wire kit and get the adapter?
- Also, I am seeing wire kits anywhere from around $30 to $100. If you don't have a full MSD wire set up and built motor, would you notice the difference in spark plug wires between the median range wires or higher end wires?
Thanks in advance...
