The left side of my engine lid [drivers side] where it meets the trunk sits about 10mm too far forward. To deal with it, the PO just mounted the trunk further back. I tried to adjust it yesterday, so that I can also realign the trunk, but no matter what I do I can't get it to fit any better - the hinge on the lid is as far back as it can go, touching the firewall.
Is there a trick to this that I'm missing? My first thought was to trim a few mm off the end of the hinge and make the slot in it bigger so I have more back and forth play to work with.
Even if the brackets were welded back on the firewall in the wrong position I don't see how that would effect the forward and back movement.
