P0 - 1
Itchy y Slime - 0
I've pretty much decided to toss in the towel on the multi fusebox fiasco. The previous owner has rendered the harness/fuse block "unmappable" to us mere mortals. My pal and I have spent approximately 72 perfectly good weekend hours over the past three weeks trying to come to grips with it. (It's been pretty well documented on pelican but, we have uncovered more "fiasco" than I feel is worth the time.
Here's my situation: I've got an opportunity to nab a 74 parts car that is intact and none of the wiring has been messed with. (the motor is a 2.0 carb'd replacement but apparently the FI wiring for the 1.8 is still there and unmolested)
IS it possible to plug and play the front harness?
I've been studying the Bowelsby wiring harness guide and it looks like it should be fairly pain free. (I plan to attempt to pretty much "transplant" EVERYTHING from the the Dash of the donor car, including the steering column as the wiper switch seems to be broken in mine)
Will I need to transplant the Fuel pump to the front under the tank?
PLEASE chime in.
My pelican thread
http://forums.pelicanparts.com/porsche-914...3-1-7-help.html
