QUOTE(Spoke @ Sep 2 2015, 09:10 PM)
Connecting the battery:
Reasoning is if you connect the negative first, then the positive, you run the risk of shorting the positive terminal to the chassis with your wrench as you tighten the positive terminal. The negative terminal is connected to chassis and you may weld your wrench to the chassis or battery. If you connect the positive first with negative unconnected, if you touch your wrench between positive terminal and chassis, there is no path back to the battery.
However this wont save you when you are tightening the velocity stack holddown nuts on Weber 40 IDFs on the battery side of the engine.
And the wrench rotates perfectly to touch the POS battery terminal.
My son did this while I watched from the driver's side.
The wrench touched the terminal, spark, and my son let go and looked up at me to do something....
I just said : THERES NO SWTICH , KNOCK IT LOOSE
By the time I ran around the car and knocked it loose, the wrench was glowing red hot.
And all of that current was going through a carb full of fuel....
