QUOTE(rhodyguy @ Sep 2 2015, 06:06 PM)
Drain the fuel tank ( you can do this with the existing pump) with a length of Hose and a catch can. I would plan on a new self regulated rotary fuel pump. remove, inspect and clean the fuel tank. replace the filter sock and new proper gaskets in the bottom of the tank. Flush the fuel lines in the tunnel or replace with stainless steel ones. Replace ALL of the soft fuel lines with modern fuel appropriate ratings. Replace fuel filter, it should be installed in prior or upstream from the pump. Buy a weber manual. At a minimum the idle jet circuitry is probably fouled. Study the manual.
Well, I did remove the tank, drained, then swab the inner lining with lint free tallows then rinsed with fresh gas, and reinstalled. I filled the fuel line with seaform which sat over night, then blew it out with my air gun. Then replaced all the rubber hoses. I then placed one 10micron filter and two 5micron filters then a final 2micron filter, with a reading of 2-3 psi at the carbs. All it did was slow down the intervals
of poor running.
I've owned webers idf for over 35 years now and have always successfully cleaned then right down to drilling and brushing out the channels then re-plugging the ports. I also have 150+$ worth of jetting. Webers can be a lot of fun to play with.
I was just hoping to hear from someone that can confirm that this is a bacteria due to the alcohol in the fuel. Like most life forms it can multiply from very few very quickly.
I read about a chemical additive that is added to diesel fuel that kills microbs,
in the trucking industry, but it is expensive and I found nothing posted as to it
success as a treatment.
My final solution will be to have the tank boiled, and replace the center tunnel fuel line.
Again, just wondering or hoping someone could enlighten me on this enemy life form.
As a sideline I will be conducting an experiment with a bleach and gasoline mixture
to see if it dissolves this jelly mass, allowing it to pass the through the 55idle jets
(which seem to be the apex of my problem) and have it burn in a normal way. I'll start with a 3% mixture then go from there. I will use an old lawn mower engine as my, white lab mouse. The goal is to make a one shot treatment.
This may all be related to a meteor that landed in my back hay field some 6 months ago. Most of the grass/hay is dead, leading up to my garage.
HAHAAHHA!!!
thanks
Frank aka Barringtonpro
