QUOTE(puffinator @ Sep 6 2015, 04:20 PM)
the AFR (air/fuel ratio) went from the 10-11s below 4000 rpm and were at 13.38 at 6200. I am running 32mm venturis and the tuner suggested i might want to go up. I'll post another picture or graph of hp, torque, AFR. Lambda was running at .91 at 6200
I think you bought the high compression version, I bought the 'low' compression
version. I ended up with about 9.2:1, and one side of the engine needed .5mm
base gaskets.
Don't listen to tuners unless they are weber experts. I highly doubt that you need
a larger than 32 venturi for a streetable 2.3L.
