Working on identifying rust on the floor under the pedal cluster. I cleaned the surface rust off, but have a couple of questions.
On the underside - what is this support for and why does it have a big hole in it?
On the inside it had a circular plug that came out and the area is filled with seam sealer. Should the seam sealer go through to the outside?
