Beakster
Sep 6 2015, 08:28 AM
The 914 I just bought has got a set of headers .. So No heat .. I need heat in the car .. Any Ideas on what I can put in or use .. Has any one put in a VW gas heater in there 914 ??
JmuRiz
Sep 6 2015, 09:03 AM
Important question: /4 or /6?
Makes a huge difference in your options per dollar.
era vulgaris
Sep 6 2015, 09:34 AM
Check your exact same thread in the FS parts forum. You've got a couple replies.
Beakster
Sep 6 2015, 09:58 AM
QUOTE(JmuRiz @ Sep 6 2015, 09:03 AM)
4 2.0
JmuRiz
Sep 6 2015, 01:12 PM
Phew, there are typically some 2.0 SSI heat exchangers for sale in classifieds. Post a WTB ad and you'll find a set. If you need the other heater bits, I want to say I've seen some ads recently for flapper boxes and j tubes.
Mark Henry
Sep 6 2015, 04:12 PM
It's a trade off.
Depends on the headers, but good headers make HP, you'll very likely lose HP with SSI's.
Stock engine, headers ballpark around 7 to 15 HP, which makes it the biggest bolt on power increase you can do.
But a gas heater or good exchangers (like SSI's) are the only proven methods for good heat.
Likely what I'll do on my /6 conversion is a diesel bunk heater from a truck and I'll add a small tank for the fuel.
porschetub
Sep 6 2015, 04:35 PM
QUOTE(Beakster @ Sep 7 2015, 02:28 AM)
Option are;
1 - get a VW gas heater rebuilt so its safe.....expensive and still not that safe,
2 - get a good fabricator to box in your headers and use existing system.....still won't be very warm in Canada,
3 -purchase and fit a small motorhome diesel powered heater....very efficient,but where do you mount it.
4- Electric powered one....you would most likely need a separate battery ,wiring and a split charging system,again not an easy solution.
boxstr
Sep 6 2015, 07:18 PM
Seat Heaters.
Craig at CAMP
Cracker
Sep 6 2015, 07:19 PM
I have an acquaintance who did install an electric heater and it works great...I'll probably do the same eventually.
Tony
Kansas 914
Sep 6 2015, 08:28 PM
QUOTE(Cracker @ Sep 6 2015, 07:19 PM)
Tony
I would be interested in the details. Especially current draw.
Mark Henry
Sep 6 2015, 09:16 PM
QUOTE(Cracker @ Sep 6 2015, 09:19 PM)
Tony
Maybe great in Atlanta....
Cracker
Sep 7 2015, 06:35 AM
Easy now...it can get down in the 20's (at times)!
Tony
QUOTE(Mark Henry @ Sep 6 2015, 10:16 PM)
Tony
Sep 7 2015, 06:54 AM
There's nothing like a good set of stock he's. Burn you out of the cabin heat.
saigon71
Sep 7 2015, 07:22 AM
The stock heating system is excellent if you don't mind losing a few HP from dumping the headers.
Mike Bellis
Sep 7 2015, 10:00 AM
I saw this attempt at heat on a car at Original Customs. Not sure what the finished product looks like but as is it looks like it would suck burnt oil smoke into the cabin.
QUOTE(Cracker @ Sep 7 2015, 07:35 AM)
What about when it is colder than sweatshirt weather?
GaroldShaffer
Sep 7 2015, 04:49 PM
QUOTE(mepstein @ Sep 7 2015, 07:54 AM)
100% a complete working stock heating system can bake you out of the car.
r_towle
Sep 7 2015, 06:24 PM
Don't drive a 914 in the winter in Canada....buy a cheap winter car.
ChrisFoley
Sep 8 2015, 06:52 AM
QUOTE(Mike Bellis @ Sep 7 2015, 12:00 PM)
Then maybe you should withhold from commenting on something you really know nothing about.
era vulgaris
Sep 8 2015, 09:12 AM
QUOTE(Racer Chris @ Sep 8 2015, 08:52 AM)
Not sure if that's an actual Tangerine heat exchanger in the pic or a copy that someone made themselves, but I've got a Tangerine heat exchanger on my car. It works great, and there are no fumes whatsoever in the cabin.
sean_v8_914
Sep 8 2015, 10:03 AM
use an external oil cooler as a heater core or pay chris for his heat/header box. it works.
Cracker
Sep 8 2015, 10:52 AM
Ok. Here's the scoop...he came across a truck stop (no, this isn't the beginning of a joke) and found they have great accessories. He has a 12v ceramic heater & a truck (12v) hair dryer plumbed for the defrost. He claims it will make you sweat eventually, very effective.
PS: I forgot...he powers these two on a 30 amp relay.
Tony
quote name='Kansas 914'
[/quote]
[/quote]
76-914
Sep 8 2015, 05:48 PM
QUOTE(Racer Chris @ Sep 8 2015, 05:52 AM)
Chris, is that your design? How'd I miss this? It's something that was always in the back of my mind. I made one for a plane once . But, I really like your approach. Out of the box, no pun intended.
914_teener
Sep 8 2015, 05:59 PM
QUOTE(sean_v8_914 @ Sep 8 2015, 09:03 AM)
Oil cooler for a heater is a World myth....the required temp. split for somewhere like Canada won.t happen Sean.
I should say for an aircooled motor.
porschetub
Sep 8 2015, 06:13 PM
QUOTE(914_teener @ Sep 9 2015, 11:59 AM)
x2 no way
,old wives tale for sure.
ChrisFoley
Sep 9 2015, 06:20 AM
QUOTE(76-914 @ Sep 8 2015, 07:48 PM)
Yes.
Fully assembled
Sep 9 2015, 12:14 PM
