Sea Dragon 914
Sep 7 2015, 09:54 PM
It's been a very long time since I did this. How do you remove the rear chrome trim piece? Do you pry from the top or bottom? Suggestion of what to use (putty knife?).
Thanks,
SD
ConeDodger
Sep 7 2015, 10:31 PM
Held in with clips. Just keep pulling without pulling so hard you bend it...
PanelBilly
Sep 7 2015, 10:38 PM
If you're talking about the one that curves down, there is a nut ho;ding in on under the rear fender
Sep 8 2015, 05:12 AM
QUOTE(PanelBilly @ Sep 8 2015, 12:38 AM)
I think the nut is 8mm
Sea Dragon 914
Sep 8 2015, 09:37 AM
QUOTE(mepstein @ Sep 8 2015, 04:12 AM)
No, it's the long horizontal one. I recall pulling on it or gently prying it off.
Kansas 914
Sep 8 2015, 09:54 AM
QUOTE(Sea Dragon 914 @ Sep 8 2015, 09:37 AM)
3 clips holding it
whitetwinturbo
Sep 8 2015, 10:00 AM
...........nice if we could see a picture of location of 3 clips
ConeDodger
Sep 8 2015, 10:30 AM
QUOTE(whitetwinturbo @ Sep 8 2015, 12:00 PM)
They are floating clips. So the location could be anywhere after all these years. They should be spaced evenly for reinstall but don't be shocked if they're all right next to each other...
76-914
Sep 8 2015, 04:38 PM
And don't be surprised if one shoots off into a deep black hole or is broken. IIRC, Sierra Madre sells these clips.
76-914
Sep 8 2015, 04:39 PM
TargaToy
Sep 8 2015, 05:22 PM
QUOTE(76-914 @ Sep 8 2015, 06:39 PM)
This would describe the lucky magic that takes place inside my garage.
rhodyguy
Sep 9 2015, 11:11 AM
the 2 outside clips are roughly 3 1/2-4" from the ends and the 3rd looks centered judging from the rust stain witness marks.
AZ914
Sep 9 2015, 11:52 AM
Once I had the side curved pieces off (I think), I was able to slide the long horizontal one off one end as the clips move.
ice cold
Sep 9 2015, 06:55 PM
I slid mine sideways to clear the clips, worked fine, no damage.
Sea Dragon 914
Sep 10 2015, 11:52 AM
QUOTE(ice cold @ Sep 9 2015, 05:55 PM)
Good tip. I did it the hard way. Worked from one end prying gently with a flathead screwdriver. Got it off without damaging it. Sounds like your way is much easier and I"ll make a note of it so when I do this again in 15 years, it will be easier and less stressful.
