QUOTE(euro911 @ Sep 8 2015, 12:24 PM)
The system Kent and I attempted to install using Honda components didn't turn out as well as we were expecting, so I'm back to square one.
I just took possession of the Wilwood components this morning and waiting for a bracket to mount the M/C. Once I have everything here, I'll be ready to tackle this project, but it would be nice to have an extra hand or two or ... to get it installed ... the more the merrier
Any local guys want to come help
As customary, liquid refreshments and nutritious snacks will be provided
Here is the site I looked at to do the install. I am installing a 915 and the coverage indicates both the 901/915 trans is the same.
http://diablo.kitcarmagazine.com/current_p...ransmission.aspHere is the terminology. I would love to come by we could do two conversions if you select this design and recommendations.
Clutch
Because of the cradle mount I was not able to mount the slave cylinder on the original location. I also did not like the fact it would point toward the rear were there is just simply no room to spare. After staring at it for over an our and thinking of a hinge type to reverse the mounting position I decided to simply make a bracket welded to the other side of the clutch arm.
http://diablo.kitcarmagazine.com/current_p...Images/wpe1.jpghttp://diablo.kitcarmagazine.com/current_p...Images/wpe2.jpghttp://diablo.kitcarmagazine.com/current_p...Images/wpe3.jpg Here is the Clutch shaft before putting the linkage. With the stock linkage installed it was evident that there was not enough room to install the slave cylinder. The arrow indicate where the original linkage rod that would be pulled toward the back of the transmission.
http://diablo.kitcarmagazine.com/current_p...ages/wpe4sa.jpg Another view of the stock linkage. Here is a picture of the bracket welded to the other side. There are actually two pieces welded together in a triangle to added strength. We measured from the center of the shaft to the stock location of the original rod mounting hole (5 1/4") and mage the exact lenght and hold on the added bracket so the pivot would be the same as the other side but moving in the opposite direction.
http://diablo.kitcarmagazine.com/current_p...ages/wpe4sa.jpg Another view of modified linkage You can see here the now and the original rod linkage hole
http://diablo.kitcarmagazine.com/current_p...mages/wpe5a.jpg Here is the Wilwood slave cylinder temporarily attached to the linkage. With the new location there is plenty of room for the slave cylinder. *Note how the bracket was welded. You can see the two pieces together here.
http://diablo.kitcarmagazine.com/current_p...mages/wpe8a.jpghttp://diablo.kitcarmagazine.com/current_p...mages/wpe6a.jpghttp://diablo.kitcarmagazine.com/current_p...mages/wpe9a.jpghttp://diablo.kitcarmagazine.com/current_p...Images/wpeA.jpg Another view of the assembly
http://diablo.kitcarmagazine.com/current_p...Images/wpeB.jpg
