Greetings;
I am in the process of removing the intake tubes, injectors etc on a stock 1974 1.8 L-Jet. I obtained this 914 from my father-in-law a few years ago now and still plugging away to get it running again. I know that years ago [mid 1980's] my brother-in-law pulled the engine and had the long block rebuilt. He was a pretty good mechanic.
I noted that one intake tube flange has a stamped "1" and the other stamped with "4". I thought my brother in law swapped the manifolds side to side in error since the "4" was on the side with cylinders 1+2 and the manifold stamped "1" was on the 3+4 cylinder side. I cleaned and painted the intake tubes today and tried to put them back on. I put the one marked "4" on the 3+4 side and it does not fit very well at all. Same thing on the other side. I also noticed that if the intake are "swapped" the welded on vacuum hose clamps on the intakes face to the rear where they would do no good.
Does anyone know if it matters? Am I confused?
Thanks for any input.
Dennis
