Tom73
Mar 4 2005, 05:11 PM
The rubber coated push clips that hold the rear grill and PORSCHE letters on to the grill, anyone got a good source for replacements. Have checked one of the 914 vendors and they are $2.40 each (uses 26 of them).
tom...
jwalters
Mar 4 2005, 05:18 PM
QUOTE (Tom73 @ Mar 4 2005, 06:11 PM) |
The rubber coated push clips that hold the rear grill and PORSCHE letters on to the grill, anyone got a good source for replacements. Have checked on the 914 vendors and they are $2.40 each (uses 26 of them).
tom... |
If you have a lowes building center nearby they sell them---in the hdwr department in the specialty bins--that were i got mine from--12 cents each---
Tom73
Mar 4 2005, 05:21 PM
QUOTE (jwalters @ Mar 4 2005, 03:18 PM) |
QUOTE (Tom73 @ Mar 4 2005, 06:11 PM) | The rubber coated push clips that hold the rear grill and PORSCHE letters on to the grill, anyone got a good source for replacements. Have checked on the 914 vendors and they are $2.40 each (uses 26 of them).
tom... |
If you have a lowes building center nearby they sell them---in the hdwr department in the specialty bins--that were i got mine from--12 cents each--- |
Would you have a part number? I just came from Lowes about 30 minutes ago. The staff there did not know of them. With a number they may be able to order if they don't stock.
tom...
jwalters
Mar 4 2005, 05:26 PM
Sorry no--no part number--but they have them--if they keep the stock up--they should be clearly marked in the specialty fasteners plastic bins--you may have to poke around a little in the drawers to find them....
jwalters
Mar 4 2005, 05:27 PM
I used the quick turn nuts and really small grommet that went inside the nuts--just like many stocker cars had
Tom73
Mar 4 2005, 06:25 PM
QUOTE (jwalters @ Mar 4 2005, 03:27 PM) |
I used the quick turn nuts and really small grommet that went inside the nuts--just like many stocker cars had |
Now I'm confused, and in my case that happens very easily
What you got at Lowes, was it the rubber coated push clip or a quick turn nuts and really small grommet?
tom...
jwalters
Mar 4 2005, 06:47 PM
YEA--thats it!
J/K
Your choice--they have them both--I like the nuts cause they stay there with the tension--the rubber fills the gap and gives vibration dampning
Spoke
Mar 4 2005, 07:10 PM
I couldn't find the push clips so I went to the hardware store and got a die that just fit on the studs of the PORSCHE letters, and threaded the studs. I painted regular steel nuts black and mounted the letters. Same with the grill, except I didn't thread them, just screwed on the nuts.
Spoke
DonTraver
Mar 4 2005, 07:52 PM
Go to a paint and body supply store. You can get packs of them, usually 15 to 20 per pack for about $2-3. Look on the carasel (sp) thingy.
Later, Don
