S O L D !!! Thanks!
Removed this from my racecar, switched to Rich Johnsons bracket, as this one would not work with my new GT Rally Muffler/Header setup. Pelican sold this many years ago, discontinued some time ago. It will not include a 914/6 throttle cable, or a correct 914/6 bell crank. I will include one you could convert. it could be 911, or 912. I do not know.
From the old PELICAN ad:
This linkage kit is a must for 914-6 conversions. It avoids the nasty process of drilling through your 901 transmission intermediate plate to mount the bell crank. The kit contains four pieces:
•A special bracket and crank that mounts to the bolts on the rear cover of the 901
•A 914-6 bracket that holds the end of the accelerator cable
•A 914-6 accelerator cable that replaces the 4 cylinder one
•A 911 throttle rod, that can be used instead of the expensive 914-6 throttle rod because the bell crank is further back on the transmission.
Link to the old ad;
http://www.pelicanparts.com/914/914-6_cons..._price_list.htm
