QUOTE(Dave_Darling @ Sep 16 2015, 10:44 AM)
I've found that leverage and wiggling can move stubborn parts. I'd probably put the wheel back on the hub, loosen the retaining nut (but don't remove it!!) and then grabbing the outer edge of the wheel at 3 and 9 o'clock and pulling on each side alternately.
--DD
True Dave but has someone wound up the nut with the wrong spline on the wheel adaptor...seen it before.
Agreed that the wheel needs to be on there to get it moving however.
