QUOTE(Jeff Bowlsby @ Sep 16 2015, 09:38 AM)
Check the chart again, all 74-76 2.0L use the same 043 MPS.
Thank you Jeff !
After installing the MPS from a 1975 car my car runs entirely different.
I always thought that the MPS held vacuum or failed, this is not the case, I think I've been fighting a slow leak through the MPS for years.
For the first time in a long while my air bleed screw at the throttle body actual works!
after installing the new MPS the idle was at 1500RPM, a twist of the screw brought it down to 1K. My throttle response is smooth and the car runs fantastic.
