mikey13
Mar 5 2005, 12:13 PM
I have a 72 1.7L motor and i'll be bolting a 73 sideshifter tranny to it and i need some help with the front motor mounts i have the engine bar and the end mounts but i'm missing the small rubber pucks and the 'L' type brackets that bolt onto the motor if and i cannot seem to locate any of the small L brackets locally so i was wondering if somebody could post some pictures for me and maybe some dimensions of the part so i can fabricate my own or if theres any tricks or such to make this process easier
thank you
-Mike
SLITS
Mar 5 2005, 12:21 PM
Someone will have a right and left (yes, right and left late motor mount). I don't think I have any left to image.
The rubber donuts that mount the engine to the bar...buy them new...sorry, but they break to easily to rely on used ones.
Maybe tomorrow I can get to my shop and shoot an image of the mounts and dimension them for you to "fabricate" your own.
Put a "wanted/needed" post in the classifieds.
mikey13
Mar 5 2005, 12:26 PM
i plan on ordering new motor mount rubbers, no sense in using old ones. The ones i have are shredded anyways so those are easy to get. so the 2 brackets that connect the rubber mounts to the block arn't interchangeable?
Triaddave
Mar 5 2005, 12:45 PM
mike, i just found the r/l brackets you need. for what it is worth, the rubber even seems to be in good shape. i can ship as is, or run them through the bead blaster and paint. e-mail me and we'll figure out how to get them to you.
SLITS
Mar 5 2005, 12:48 PM
See, if you believe, it will happen
Rhodes71/914
Mar 5 2005, 03:52 PM
I did this conversion recently and used the L brackets that were already on the engine and it seems to work fine.
What kind of issues am I going to have down the road?
jr91472
Mar 5 2005, 06:34 PM
QUOTE (Rhodes71/914 @ Mar 5 2005, 01:52 PM) |
What kind of issues am I going to have down the road? |
when I did my conversion, the early center backet was a single piece (no l/r) just one big bracket.
is this what you are referring to?
JR
Rhodes71/914
Mar 5 2005, 07:10 PM
Oops! as soon as I saw another reply to this post i realized my mistake before I even read it.
Yeah I did a conversion, but I also used a different engine that is a '75 and it obviously had the the correct mounts. I'm sure the 1.7 sitting on the garage floor has the older style mount.
tat2dphreak
Mar 5 2005, 08:05 PM
Jwesteng.com has sweet metal and alternative composite ones... you should consider them...
Joe Bob
Mar 5 2005, 08:22 PM
Been awhile since I have done 4 bangers...but don't early 911 sport mounts work when ya oval out the holes?
Mar 5 2005, 08:26 PM
QUOTE (mikez @ Mar 5 2005, 06:22 PM) |
Been awhile since I have done 4 bangers...but don't early 911 sport mounts work when ya oval out the holes? |
nope, you're talking about the wrong mounts ...
he needs the mounts and brackets that go between the engine and the crossbar, not the mounts for the old crossbar to the chassis ...
911 sport mounts work very well as transmission mounts, btw. ...
Andy
