i cant seem to get the shifter bar to come loose. I removed the screw(where the arrow is) and i lightly tapped it with a mallet but i wont break loose. What should i do?
jwalters
Mar 5 2005, 04:20 PM
Put a vice grip on very low tension upstream of the shift tube--only enough to grab it gently and not cave it in or mar it up too much--then rotate it from side to side in very small increments while putting tension on it towards the firewall--and it will come out-
That siezure is just from years of being mated up---
Rusty
Mar 5 2005, 04:21 PM
Get someone to sit in the passenger compartment. Have them put the shifter in 2/4 gear, and hold it.
Sometimes all you need is to keep pressure on the shift rod in the opposite direciton.
Then take a mallet and tap the fitting loose.
-Rusty
mightyohm
Mar 5 2005, 04:41 PM
Some liquid wrench won't hurt.
grasshopper
Mar 5 2005, 04:45 PM
thanks for the advice!
