Well I sorta
with Rob at post #2 ....
There was one or two or ?? early press photo's of at least one prototype 914-6 with a crest hood badge, & the "custom made" 914-8's for Ferry Porsche & Ferd. Piech had them.
And then any dealer could add them at customer request or if they thought it helped sell them - IIRC it was Rusnak Porsche in Pasadena CA that did it to all 914s .... or one of the SoCal dealers .... & maybe others.
IMHO they look best on a 914 as close to the front edge as you can get & still clear the underside framework.
The 80 mm was for the 911/912 hood/front lid, but it didn't have the extra front length of the 914's bumper in front of it.
Some folks still use that dimension, others use a line across the tops of the headlight doors, & others split the difference & center them on the headlight doors (set an "X" between the top inside corner & opposite lower inside corner of the headlight doors), & all sorts of spots in between those.
So bottom line, look around at as many as you can find by googling or binging (??) for images of 914s with hood badges, then put it where YOU like it's look!
Good Luck!
Tom
