QUOTE(RobW @ Sep 22 2015, 05:39 AM)
It depends. You can lighten the heck out of a door by taking the window and crank out, cutting everything out from the inside including the frame and covering it with a thin aluminum sheet. Then you can wear a thick jacket when its cold.
If its for the street, I recommend not lightening it at all. The safety metal is there for a reason.
Most of the guys I know/knew racing 914s do this & as shown on the blue car - with the aluminum skin added after removing the factory bracing.
The ex-racer shell I got for body parts on my resto - those guys kept the frame in the door (uncut) & used aluminum skin (thinner since factory frame was intact), since they were racing in vintage & not trying to overly modify the car so as to stay in their unmodified class.
If they were racing in cold &/or wanted to keep it aerodynamically clean, then they added polycarbonate "glass" (inoperable/fixed but pop-out/-in for access/escape).
Also agree to keep it all stock for street use.
Tom
