QUOTE(turk22 @ Sep 23 2015, 10:56 AM)
Harve,
I sent you a PM, I'll check around for a shop
SteveT
Thanks. I found European Auto Specialists. They were methodical in determining that the problem was a failing starter and solenoid. I may not have all of this correct, but the solenoid was trying to draw more current than the relay on the hot start kit would provide. With a 15 amp fuse in the link, the solenoid would blow it every time as it tried to draw my current to make the connection for the starter.
Bob is a seasoned mechanic that really went through the wiring to figure out the problem. This experience is worth sharing with others who have a hot start kit linked to an aging starter solenoid. It's formula to leave you stranded.
We upped the fuse to 20 amp since the Bosch relay is actually rated for 30 amps. We moved the relay and fuse to back engine firewall to make it more accessible and in a cooler place rather than hanging out in a very hot place by the starter.
European Auto Specialists were very generous and gave me a loaner car to use while they fix the 914. BTW, Cincy is a great town. I've never been here before, but it's a great place if you have to get stuck with breakdown.
