QUOTE(Andyrew @ Aug 1 2016, 04:45 PM)
QUOTE(3d914 @ Aug 1 2016, 12:25 PM)
Tom, Thanks for sharing all your painting details. It looks great. I'm curious how much difference the single stage makes in getting the results you're after? Not sure how much painting experience you have. I'd like to take on the painting myself (also using single stage), but with little experience at this I wouldn't want to do it twice.
Any insights you can offer?
Single stage is a great step into painting.
You can read the first part of my build thread for more details on painting with single stage, or my other paint thread in my signature for me painting Peters car as well as the issues we had with bad paint.
Painting with single stage can easily be done in the garage for a nice driver quality paint job.
Andyrew
I just went back and looked at your body work.... Damn, I though I took a lot of pictures.. Ha-Ha.
That's pretty much what I went through also. Your car turned out nice. I hope mine buffs out that good
3d914
This is the first car I have painted. I have done paint and moulding on a my motorcycles and some bodywork on an old Mustang but that was in my teen years.
I chose the single stage PPG because I thought it would be easier to fix any flaws or mistakes. rather than having to go through a layer of clear coat. Also in the future I could shoot a clear coat or a single stage / clear coat mix. so I'm not locked into this.
Same as Andyrew I used a combination of glass fiber, and polyester body filler, I used Rage Gold. and some evercoat glazing putty then sprayable body filler - Slick Sand. I shot the Slick Sand with a 2.5 tip spray gun. it really lays it on but get it out of the gun quick because it sets up fast and will plug up your spraygun. Same with the high build primer. I used a 1.8 tip with the PPG K38 High build primer, and you get 20-30 min at best before it quits spraying and you have to hurry to clean it out of your spraygun.
Read the sheets on the paint and primers and keep very close to those times and mixes. Temperature is also very important, I used a digital IR HF thermometer to make sure of the body temp. and match the reducer temp range to that.
Not being a bodyman I found it hard to determine what was good enough and probably did too much prep work, if you can. you really need kind of an artists eye to get the lines right. I struggled with this a lot.
I think you have to accept that 99% of the people that look at your car. (bodymen excepted) will never see the little things you work so hard to get just right. Just try to keep yourself from pointing out to people the tiny flaws that you know are there.
