Stacks914
Oct 1 2015, 12:20 PM
Can anyone recommend a good tube bender? 1-3/4
Thank you!
76-914
Oct 1 2015, 04:35 PM
Good for what? Going to make roll cages or exhaust systems for a living? Need to make an engine cradle once?
crawler
Oct 1 2015, 05:04 PM
JD Squared, Inc.
r_towle
Oct 1 2015, 05:56 PM
Lowbucktools
Stacks914
Oct 2 2015, 12:15 AM
Cool I was thinking about just going with Jd squared as it's not too terribly priced. 76 I have two Porsches and like to buy quality tools. Both will require cages or might just make two cages. I have seen great reviews of the Jd squared product. Now while I will not be working in shop it might get used for a couple weeks a year or so. and I will check out low buck tools thanks guys!
ChrisFoley
Oct 2 2015, 01:00 AM
1 3/4" is overkill for a 914 roll cage.
1 1/2 x .095 DOM is the standard size for SCCA and PCA for small cars.
Stacks914
Oct 2 2015, 01:25 AM
Cool man THANK YOU!!! Do they follow the under 2500lbs rules still? Also do you have any idea where I can source the tubing around Omaha Ne. Currently I am at about 7.15 a foot to my door?
ChrisFoley
Oct 2 2015, 06:25 AM
QUOTE(Stacks914 @ Oct 2 2015, 03:25 AM)
Yes, 2500lbs and down require 1 1/2od x .095w DOM.
You could buy a complete roll cage kit from me, delivered to your door.
At the moment I have two orders to fill. I'll be bending tubes later today.
ThePaintedMan
Oct 2 2015, 10:07 AM
Buy Chris' cage. It's a work of art. Fits better than anything else out there, will keep you SAFE, and he ships it to you.
Stacks914
Oct 2 2015, 10:30 AM
Chris as much as I have been drooling over your cage for some time now I will be building a sub frame for a corvette suspension front and rear and then tying it all together. With of course an ls engine and boxster trans. I do not know my exact requirements that I will need just yet! Plus i really want to try and do it myself! Appriciate your input though!!! I am down to 4.16 a foot with the new size! Thnks again man!
jd74914
Oct 2 2015, 10:42 AM
QUOTE(crawler @ Oct 1 2015, 06:04 PM)
JD Squared, Inc.
Their Model 3 manual bender works great! A local Lemons team has one with a 2" receiver mount so it can be easily transported and used off a truck.
Chris' cages are really nice though...and bending tubes to perfectly follow the windshield and targa bar contour aren't super easy...
Stacks914
Oct 2 2015, 12:52 PM
Oh you make it sound so sexy...
QUOTE(jd74914 @ Oct 2 2015, 08:42 AM)
JD Squared, Inc.
Stacks914
Oct 2 2015, 02:09 PM
Also what CLR die do you guys use/recomend?
ChrisFoley
Oct 2 2015, 02:38 PM
QUOTE(Stacks914 @ Oct 2 2015, 04:09 PM)
Most race organizations require bend radius to be at least 3x tube diameter.
I have a 1 1/2"OD X 4 1/2"CLR die set for my Hossfeld bender.
914forme
Oct 2 2015, 02:48 PM
ChrisFoley
Oct 2 2015, 02:58 PM
IMO, a 7" bend radius is too large for a 914 roll cage.
Hard to make the roll cage fit well when the bend radius is too large.
914forme
Oct 2 2015, 03:06 PM
Good point Chris, and they only go down to 5" for 1-1/4" so if you plan on doing anything with a sanctioning body, you better read the rules.
So unless your building a sub 1500 lbs car that will not work.
Stacks914
Oct 2 2015, 06:51 PM
Wow thanks for all the info!!!! Everything I needed, I heard mixed reviews on affordable tube benders while the price looks attractive it sounds like the quality of the workmanship and customer service was not. Anyway thanks again Everyone!!!!
