QUOTE(era vulgaris @ Oct 6 2015, 10:13 AM)
QUOTE(somd914 @ Oct 6 2015, 05:51 AM)
I'm not professing to remove your rain tray, just not sure why people feel it's bad to get the engine wet?
It's not the engine getting wet that worries me, it's the battery. Which is why I still don't get why they put it right under the side grill vent opening.
What setup are you running? As I said, I had no difference in idle or cruising temps with or without the tray, even in the dead heat of summer.
Sorry, I should have more specific. I don't have a CHT gauge, but it's on my list...
I'm running a 2056, dual Webers, stock oil cooler.
Prior moving away from the traffic mess, I used to have a six mile stretch that was a 1st-2nd gear crawl, generally took 25-30 minutes to get through it. On those occasional days of taking the teener to work and crawling through this stretch, if air temps were 85-90 I'd see the oil running perhaps 5 deg warmer with the rain tray removed, but no discernible difference once moving.
I did notice a cooler engine compartment while sitting and idling - based on non-scientific experiments I observed the engine bay staying 10-15 deg cooler w/o the rain tray based on idling, but no measurements in stop-and-go traffic or while underway, but assume there would be enough airflow to minimize any difference once constantly moving.
So yes, slightly cooler temps in stop-and-go traffic but nothing really notable.
Understand about your concerns regarding the battery, which as we all know was a poor design. I used to run Optima Red Tops, but after several issues, I plan on moving to an Odyssey soon.
