Yesterday I finally cracked the case on the damaged taco plate engine and found this mess on the camshaft bearings. It looks like the bearing coatings started to come apart. One side is completely missing the coating and the rest are deeply gouged. One would assume the camshaft journals would be scratched and gouged to match the cam bearing BUT they are untouched.
The camshaft rivets are loose and the gear MOVES about 1 mm on the the shaft. I am wondering what was holding this engine together.
