QUOTE(LowBridge @ Oct 9 2015, 05:37 AM)
QUOTE(Mike1981 @ Oct 8 2015, 10:19 AM)
QUOTE(LowBridge @ Oct 8 2015, 08:14 AM)
I agree that it should be removed or wear a helmet.
Once the bars are out you are also going to need to address the seat belts and seats. On the high wing racing seats standard shoulder belts some times will not fit correctly. they do make a belt bar that bolts in between the shoulder points above the firewall padding.
I will be keeping the seats and belts
Im not following your comment on the belts not fitting
I thought the belts were bolted into the rear firewall but I could be mistaken
I was thinking you would remove them and go back to 3 point OEM. however my followup comment on the cross bar is how you would want to secure the 4/5 point once the roll bar is out if they are current secured that way now as a rap around style.
If they are currently bolted through the firewall make sure you have a big/wide backing plate otherwise there is a real risk the eye bolts can be pulled through under a heavy impact.
On the other comments about "teleporting", the seats are designed to flex and the belts are designed to stretch on impact to lessen the G-force and when this happens your head is going to hit that top bar. So no teleporting will be needed to have this happen. that is just simple math...
Great point on the eyebolts and the harness. The 4/5 harness is worthless without the proper firewall install.
On the seat giving / belt giving hit your head on the top bar thing, I don't see it. Unless the top of the seat is made out of popcorn and confetti, the seat is up against the bar, and the bar against the roof. Your shoulders should be below where the harness holds you down, so you can see where your head should be. Roundish head, I think its damn near impossible to contort to hit it, unless you're in a serious serious wreck and at that point nothing will save you. Between a stock seat and the Corbeau I'd think the Corbeau would be better for you.
A harness should be worn properly with no slack. The give would be in centimeters not inches.
