Rhodes71/914
Mar 6 2005, 10:11 PM
I'm not ready to totally refinish the top but I would like to get rid of that faded look if I can.
Know of any products out there that can bring some life back into the top and possibly the sail panel vinyl too. Kinda like what rubbing compound does for faded paint.
96conv
Mar 6 2005, 10:46 PM
I think Back to Black will work well. I use it on all black trim surfaces on my 911, plastic or rubber.
Qarl
Mar 6 2005, 10:58 PM
Anybody know how to reproduce the pebble texture to near original?
What is the process for redoing the pebble texture? Do you sand the old stuff off first and then respray, or do you spray over the existing?
Thanks!
Rhodes71/914
Mar 6 2005, 11:23 PM
QUOTE (96conv @ Mar 6 2005, 08:46 PM) |
I think Back to Black will work well. I use it on all black trim surfaces on my 911, plastic or rubber. |
Is this something I'll find at my FLAPS?
Thanks
gregrobbins
Mar 7 2005, 12:17 AM
There was a big discussion on refinishing tops on the Yahoo 914 group. Seemed that a number of folks had used pick up truck bed liner with great success. I understand it sets up with a textured finish.
Anyone here tried it?
Type 4
Mar 7 2005, 12:53 AM
Black Chrome works too. Apply with a sponge do three coats. it lasts over a year here in the so cal sun.
iamchappy
Mar 7 2005, 08:03 AM
Ive have very good success with vinyl carpet dye, But buy the good stuff from PPG or Dupont in quarts,
I have also tried the stuff in a rattle can , its way to hard to spray on a smooth finish.
TC/914
Mar 7 2005, 08:11 AM
I refinished my top with "chip guard", it's the stuff that's sometimes sprayed on the rockers and lower panels of new cars to protect against rock chips. It comes in clear and a few colors and will take a nice semi-flat top coat to match the stock black color. You can also control the pebble finish by the number of coats applied and the length of time between coats. You can get it at all of the automotive paint jobbers/outlets. The end result is pretty perfect.
Luck,
TC
JmuRiz
Mar 7 2005, 09:59 AM
Oh come on....you can't have a post like that and not show us a picture!!!
Rhodes71/914
Mar 7 2005, 10:09 AM
Here's what we have so far -
Back to Black - Sounds like this will work for the top, sail vinyl, and rubber on the bumper top
Truck bed liner - Prolly tough but more than I want I think
Black Chrome - Sound interesting, might have to find some and read the bottle
Vinyl Carpet Dye
Chip Guard
We'll see what I come up with and I will post results when I get it done. Thanks guys.
TravisNeff
Mar 7 2005, 10:32 AM
I would think that you have to buzz down at least a little of that texture before applying new texture, otherwise it'll prolly look like stucco. Ralf Hartmann is swearing by truck bed liner that comes in a rattle can, he said 2 cans will do it. He also had pictures on his webshots site. Looked pretty good. Original? I dunno, all my 914's had their tops redone and painted and all looked different.
StratPlayer
Mar 7 2005, 10:50 AM
MarkG
Mar 7 2005, 12:56 PM
Forever Black worked for me, mail order only I believe. Do NOT order it from AA, as they will send you Tire Gel even though catalog lists Bumper and Trim conditioner.
It actuallt dyes the item black again (does not have any texture qualities to it). Did the bumpers on my '76 this weekend and they look new.
azbill
Mar 7 2005, 06:06 PM
I used Back to Black. About four coats. Don't know how long it will last in the westher. My top is in the truck all the time.
BMartin914
Mar 7 2005, 06:57 PM
I know a guy - Teknon on this bord, that used black shoe dye. The top looked pretty good at a glance. Don't know how it would hold up over the years though.
jim_hoyland
Mar 7 2005, 09:39 PM
I saw a car pait shop use that stuff they sell at pep boys to coat the inside of the wheel wells. Came out real good; be sure to wear a real dust mask, the stuff is very strong.
AZ914
Mar 8 2005, 10:45 AM
I used the truck bed liner approach. The look is very nice. You can vary the texture depending on how far back you hold the can.
I put mine on pretty fine so it ended up a little rough to the touch which can be a pain for towels and wash mitts! If I were to do it again, I think I'd hold the can closer, get it on a little thicker. If you try this route, practice on some wood. Oh yeah, I sanded my top and put used the primer filler method to fill in some holes where the old texture had been rubbed through when mounted in the trunk.
StratPlayer
Mar 8 2005, 09:43 PM
redshift
Mar 8 2005, 09:52 PM
Wurth crap! Original!
You can scrape the whole thing bare, and start over... perfection in one try!
No, I've only seen it done...
M
