914itis
Oct 10 2015, 01:50 PM
Some of you may have read my old thread about my alternator not charging after eliminating all possibilities I decided to pull the intake and check the alternator.
The first thing I noticed is that the alternator's ground strap from the block is connected on top of a top of the fan which is plastic.
See picture. Is that where it should be?
Bartlett 914
Oct 10 2015, 02:44 PM
Others will probably correct me but I think The cars did not have a ground strap on the alternator. I install one because I feel is is better to have one than not. I assume the previous owner did that and made a poor choice on location
TheCabinetmaker
Oct 10 2015, 02:50 PM
Not a six guru, but I've never seen a ground strap on any alternator. Seems redundant. The case is grounded to the block.
toolguy
Oct 10 2015, 05:25 PM
That's where it goes, grounds the alt case to one of the engine case center bolts
914itis
Oct 10 2015, 06:04 PM
Thanks ,
I pulled it , will have it tested Monday at an alternator shop .
luskesq
Oct 10 2015, 06:19 PM
That is where it goes on my 911s
Keith
rgalla9146
Oct 10 2015, 07:28 PM
QUOTE(toolguy @ Oct 10 2015, 07:25 PM)
+1
rgalla9146
Oct 10 2015, 07:29 PM
QUOTE(luskesq @ Oct 10 2015, 08:19 PM)
Keith
+2
walterolin
Oct 10 2015, 10:06 PM
From Captain Krusty:
"While there is a ground strap on the 6, and it's clearly illustrated in the shop manual, there's no such thing for the 4. As there are TWO good points of contact on the 4, is makes no sense to add the hassle (and weight, for you hard core racers) of a separate ground strap. Such a thing for the 4 cylinder engine is neither shown nor listed in the parts breakdown or in the shop manual. And it's not the problem here.
The Cap'n"
5 Sept 2007
bandjoey
Oct 10 2015, 11:04 PM
Clean the grounds. After 40 years they're corroded. All of them. The whole car. It'll change your electrical life
PanelBilly
Oct 11 2015, 12:19 AM
I had a broken brush once. It would test fine and then not work for a while. Have them check the brushes.
screenguy914
Oct 11 2015, 11:58 AM
Separate grounding is a good way to insure the electrical path to battery has low resistance, especially in high current circuits. Diminished conductivity here might result in reduced charging rates.
Sherwood
9fourteen14
May 28 2017, 09:30 AM
QUOTE(bandjoey @ Oct 11 2015, 01:04 AM)
hey pal,
I know this was 2 years ago for you. but help me out...
I know there re many ground locations.... where are the ones you took care of and cleaned? I wish I had a ground map?
thanx 914 luva
JeffBowlsby
May 28 2017, 09:56 AM
porschetub
May 28 2017, 02:55 PM
QUOTE(914itis @ Oct 11 2015, 07:50 AM)
That's where it should be,the connection on to the air diverter is an altenator through bolt,it is an important connection ,you need to make sure the ends are clean or replace if its badly corroded.
