3 Weeks ago at Okteenerfest my 75-914-4 2.0 started grinding badly when shifting into 1st or Reverse. I was able to nurse it through the weekend by shifting into 1st during slow rolls and not starting car until I had engaged Reverse.
My first thought was that I just needed to tighten up the Clutch Cable as I thought that it was not completed engaging.
I got a myriad of suggestion but most thought it was dog gears or synchro's, after the weekend I put her on the tow dolly and trailered her back the 900 miles to SW Florida.
Now the Build-Off is top priority so I need to park my driver in an alternate garage so that I can go full tilt on the Build-Off Project.
Today I put the right side on Jack stands slid under there with an 11mm open end wrench and a vise grip to hold the square groove on the cable.
About eight turns to tighten the two nuts on the end of the cable and I started her up to check if I could get it into gear without the grind.
BINGO, no problem and smooth acquisition of 1st & Reverse.
Also dealing with a vapor (gas) smell, changed out the charcoal granulars form the cannister with new material from Smith & Foster, we will see if this makes a difference.
I am now having a great Sunday...Hope you are all as well
Vysoc
