I acquired a FI fuel pump from an L-Jet several years ago from a running car. Since the pump in my car was working, I stored the pump in a zip lock bag; put short hoses on each end of the pump; filled each hose with MMO; then put bolts in the ends of each hose to trap the MMO.
What is the best way to bench test the pump ? Should I just disconnect the hoses and give it 12 volts and verify it runs; or, should it be set up to pump on a gas can ? I have heard they can be damaged if run dry ?
Suggestions will be appreciated...
