Because I'm a newbie with this car I have questions to ask all you knowledgeable teeners. My 914 of 32 years ago never had a temp gauge at all but my 1973 2.0L does and it doesn't work.....where should I start? Thanks O - knowledgeable ones!
914Sixer
Oct 13 2015, 03:47 PM
Check the wire from the taco plate to the plug on the side of the engine shelf. You will probably find it is open (ie broken under the sheath). Put a Volt Ohm meter on it, check for continuity.
BeemerSteve
Oct 13 2015, 04:45 PM
QUOTE(914Sixer @ Oct 13 2015, 02:47 PM)
Thank you! I will look when I get back into town tonight.
