Just did a speed test because the site here is slower than I have ever seen it. Here are my results.
Bandwidth = 5125.6 Kbps
QUOTE (Twystd1 @ Mar 7 2005, 08:23 PM) |
Duh... I ran a "Prolog Data" MBR60 scan on the 914Club server. I see the obvious packet failure coming from the CSU side.... The fix is relatively simple.... Some dumb admin probably used KYBs instead of Koni's when they set up their gateway packet drivers...... They should also take a look at using the JWest shifter for a better point to point connection... They could also use the late bumpers with the rubber stand offs to lessen the promulgation of these packet collisions. Keeps the Apaches from running over the Sambas. Scott.... Would you like to add the finishing touches of these proposed server upgrades for the admins? |
QUOTE (Rhodes71/914 @ Mar 7 2005, 07:14 PM) |
Driving me nuts! |
QUOTE (Aaron Cox @ Mar 7 2005, 08:25 PM) | ||
man....gimme some of what you are smoking! |
