QUOTE(r_towle @ Oct 18 2015, 05:24 PM)
Jack up the car, put one front side on a jack stand, leave the other on the ground.
Grab wheel in the air at 3 and 9 o'clock
Shake it
That is tie rods
Grab wheel at 12 and 6 wiggle
That is ball joint
All wiggle, all directions is bearings.
I would do the ball joints, tie rods and bearings all at once, it's not super expensive
You will be good for another 40 years.
Just wanted you to know I did the bearings, ball joints and tie rods. I'll check back in 40 years to see if you were right. thanks again!
