Full Version: new product annoucement
scotty914
hello, i am coming up with a new product. simply it is a bolted or welded in bracket with a retaining loop for the inner axle for if the inner cv joint fails. if you have ever seen the effects of an inner cv joint failing at any speed over 5 mph, you know the damage it can do. these retainers wont stop cv damage but they will stop the cv from hitting the starter or reverse wiring on the drivers side as well as the trunk floor on both sides.
they will be custom made for your installation, to accout for ride height and tranny placement. i just need the measurement from axle top to trunk floor at you normal ride hieght, ie not measured with the car jacked up.
cost is $ 75 US shipped, all orders will ship with in 1 week
pics later this week
admins i will post this in the products section as well
Gint
Sounds like a winner to me Scott.
914werke
Is this like a scatter shield for the half shafts?
scotty914
QUOTE (rdauenhauer @ Mar 8 2005, 05:25 PM)
no its more like a cage to stop the cv joint from trashing everything under the trunk and the trunk. i have seen pics of what a cv will do when it lets loose at 40 mph. i dont think you could do that much damage with a 3 pound sledge and 1/2 hour of time.
airsix
It's like a driveline hoop for a rear-drive, front-engine car. (Do a google search) Keeps the shaft/cv from turning into Thor's hammer when one end comes loose.
-Ben M.
JWest
Good idea (I thought of it too, but did not pursue).
As airsix has said, driveshaft hoop is the common name for a device of this sort - as indicated they are very common for front engine/rear drive applications (break a front u-joint and the driveshaft becomes a pole vault blink.gif ).
xsboost90
PICS?
