this bracket contains a loop for retaining the inner axle if the inner cv joint fails. simply it is a bolted or welded in bracket with a retaining loop for the inner axle.
if you have ever seen the effects of an inner cv joint failing at any speed over 5 mph, you know the damage it can do. these retainers wont stop cv damage but they will stop the cv from hitting the starter or reverse wiring on the drivers side as well as the trunk floor on both sides.
they will be custom made for your installation, to accout for ride height and tranny placement. i just need the measurement from axle top to trunk floor at you normal ride hieght, ie not measured with the car jacked up.
cost is $ 75 US shipped, all orders will ship with in 1 week
pics later this week
