p914
Mar 9 2005, 11:21 AM
My engine started to cut out intermittently on me while driving down the highway about 15 minutes of driving. The engine gets warmed up and then I get this cutting out. Almost wants to die out but I jockey the gas a bit and it continues to run. It doesn't do it at low speeds yet, just higher cruising speeds so far. It's done this the past couple times I drove it. At first I thought maybe some dirt or debris in the fuel line, but then figured it should happen all the time if that was the case. It's about time to adjust the valves again, but it never did that before a valve adjustment.
Anybody want to throw some possibilities out here?
thanks
scotty914
Mar 9 2005, 11:26 AM
cht loose or going bad. for the loose part as the head expands the cht can get looser. either way buy a new on and put it in with a little anti seize, then you can crank it down prtty well, with out the anti seize you cant crank it down and hope to get it out later
p914
Mar 9 2005, 11:30 AM
Whats cht?
mudfoot76
Mar 9 2005, 11:33 AM
Cylinder Head Temperature sending unit
p914
Mar 9 2005, 12:09 PM
Ahh, Thank you I'll check it out.
ArtechnikA
Mar 9 2005, 12:18 PM
also check your connections to the coil.
p914
Mar 9 2005, 01:02 PM
My Electronic Ignition bypasses the coil. Thanks.
bd1308
Mar 9 2005, 01:03 PM
QUOTE (scott thacher @ Mar 9 2005, 11:26 AM) |
cht loose or going bad. for the loose part as the head expands the cht can get looser. either way buy a new on and put it in with a little anti seize, then you can crank it down prtty well, with out the anti seize you cant crank it down and hope to get it out later |
yeah thats what happened to my spark plugs.....not a problem anymore tho with the anti-seize
bondo
Mar 9 2005, 01:59 PM
QUOTE (p914 @ Mar 9 2005, 12:02 PM) |
My Electronic Ignition bypasses the coil. Thanks. |
What? howzatwork? How does it generate a spark without a coil?
p914
Mar 9 2005, 02:14 PM
jacobs I.C.E Pak uses it's own torque coil.
Mike D.
Mar 9 2005, 02:21 PM
Take one of those telescopeing magnet on a stick things and put it down in gas tank. If you pull out rust chunks, problem found. the flakes of rust can cover the screen over the pick up and starve the engine in high rpms.
jwalters
Mar 9 2005, 03:29 PM
QUOTE (p914 @ Mar 9 2005, 03:14 PM) |
jacobs I.C.E Pak uses it's own torque coil. |
What are your opinions on that ignition ???
I agree it sounds like CHT area to look at--
p914
Mar 9 2005, 04:39 PM
QUOTE (jwalters @ Mar 9 2005, 01:29 PM) |
QUOTE (p914 @ Mar 9 2005, 03:14 PM) | jacobs I.C.E Pak uses it's own torque coil. |
The I.C.E pak has been very good. i got it refurbed direct from Jacobs for $100 about 2 1/2 years ago. I had a problem with a slight hiccup before installing it and the Pak smoothed out the hiccup and the engine ran much better.
I checked out the connection on the torquer coil and it seemed a bit loose so I tightened that up. I also had a plug in part of the old smog system that seemed a bit loose and replaced it. Off to road test in a while.
I thought about something in the fuel system but it seems like I would get bad flow all the time if there was something in it. I may end up sticking a magstik down there anyway to see what may be lying in wait
Joe Bob
Mar 9 2005, 04:54 PM
Sounds fuel related to me.....filters, crud in the tank, pump going kaput can result in decreased fuel pressure at high rpms....
TravisNeff
Mar 9 2005, 05:16 PM
I'll second/third fourth that about the gas tank. Take a flashlight and peer down in there and give your fenders a wiggle. If there is crap in there (and ANY crap in there if FI) take it to a radiator shop to have them clean it out - about $80-100 bucks. Had similar problems to what you describe and this fixed it.
p914
Mar 9 2005, 06:30 PM
I replaced the fuel pump a couple years ago so it should be oK. Just started to rain a little so I'll have to wait to test drive after tightening the wire to the torquer coil and replugging the smog thingy.
I should check out the fuel cell anyway to make sure it's clean in there and see what I got. It hasn't been a problem in the past. My car has verrrrrry little rust at all. No seriously,,
Verrrry little if any at all. The guy I bought it from actually had the whole bottom undercoated. There are only 1-2 small paint bubbles by the rear tail light.. He had the car in a garage for 7 years restoring it before he decided to sell.
p914
Mar 9 2005, 08:23 PM
Light rain stopped and I got out on the test drive. No more cuttin out
Whether it was the torquer coil wire or the smog plug........the world may never know and I ain't gonna mess wit it
I think it was probably the wire. it was pretty loose.
Thanks to all who shared their ideas. Always great to have lots of input.
