Allan
Mar 9 2005, 07:36 PM
Well, I am at the point where I would like to put the oil filter on and was wondering if I should fill it with oil first? Seems like I read that somewhere.
JoeSharp
Mar 9 2005, 07:51 PM
Allan are you going to bring the motor to with oil pressure already up? It took me 15 minutes of cranking to bring up the oil pressure. I don't know if it matters (filling the filter). It just seemed like it took forever.
Joe
Aaron Cox
Mar 9 2005, 07:57 PM
even at oil changes, i fill the filter up before installing. enures me that the engine will have oil at startup...
JoeSharp
Mar 9 2005, 07:58 PM
On a new motor I don't put the plugs in till it has pressure.
Joe
Allan
Mar 9 2005, 08:08 PM
I think I'll just wait then until the start up. Thanks guys.
Aaron Cox
Mar 9 2005, 08:09 PM
what is left to do on the motor pops?
Mar 9 2005, 08:10 PM
QUOTE (Headrage @ Mar 9 2005, 05:36 PM) |
and was wondering if I should fill it with oil first? |
yes, yes and yes ...
Andy
Allan
Mar 9 2005, 08:30 PM
QUOTE (Aaron Cox @ Mar 9 2005, 06:09 PM) |
what is left to do on the motor pops? |
Top sheet metal, plenumn and intake runners. Not much really.
Dave_Darling
Mar 9 2005, 08:38 PM
Definitely pre-fill the filter with oil!!
If you didn't pack some sort of assembly lube (I hear some have used Vaseline??) into the oil pump before you installed it, then it's a pretty decent idea to take a turkey baster and squirt clean oil into the oil pickup tube inside the oil sump. I've found that I can get oil pressure pretty quickly if there's a little bit of oil in the pickup tube.
--DD
Aaron Cox
Mar 9 2005, 08:43 PM
QUOTE (Dave_Darling @ Mar 9 2005, 07:38 PM) |
--DD |
yup. i have used vaseline while packing a pump.
Mar 9 2005, 09:38 PM
QUOTE (Aaron Cox @ Mar 9 2005, 06:43 PM) |
yup. i have used vaseline while packing a pump. |
do you remember his name?
Aaron Cox
Mar 9 2005, 10:49 PM
bondo
Mar 9 2005, 10:53 PM
QUOTE (SirAndy @ Mar 9 2005, 08:38 PM) |
QUOTE (Aaron Cox @ Mar 9 2005, 06:43 PM) | yup. i have used vaseline while packing a pump. B) |
do you remember his name? |
Oh man, I laughed till it hurt! I can't think of a smiley that does this one justice.
redshift
Mar 9 2005, 10:55 PM
skline
Mar 9 2005, 10:57 PM
Yes, Wait till you come down for the startup party, I will explain why you should not put oil in the filter.
Aaron Cox
Mar 9 2005, 10:58 PM
QUOTE (skline @ Mar 9 2005, 09:57 PM) |
Yes, Wait till you come down for the startup party, I will explain why you should not put oil in the filter. |
contrary to popular belief.....????
you cant say that and walk away....
Rhodes71/914
Mar 9 2005, 11:39 PM
I've been told by some mechanics that it doesn't make a difference whether you fill the filter or not.
skline
Mar 10 2005, 02:21 AM
I have reasons and I dont want to start any bashing here but I have a legitimate, and from a reliable source reason to not fill the oil filter in a NEW engine. Only in person will I tell you.
SpecialK
Mar 10 2005, 02:43 AM
QUOTE (skline @ Mar 10 2005, 12:21 AM) |
I have reasons and I dont want to start any bashing here but I have a legitimate, and from a reliable source reason to not fill the oil filter in a NEW engine. Only in person will I tell you. |
Okay.....not you got me freakin' out Scott!
I'm "poppin' the cherry" on the 2.0L for my '73 this spring, and I was planning on filling my oil filter prior to cranking it over. Have anything with cold oil the filter and the high revs required when breaking the cam in?
JoeSharp
Mar 10 2005, 09:07 AM
Break-in starts when you slide the cylenders on. Every time you turn the motor it rubs parts. Your pre-lube should take care of all motion in the motor until it builds compression. If you fill your motor with oil and let is sit it will delute your per-lube. So don't put oil in the motor untill your ready to start it ( that is not to say that filling the oil filter is wrong) It could save you a minute before you go to the panic. I heard so much stuff going on in my start-up that I could not belive it. My goal was to do the 20 minutes or blow-up the new motor, and I got through. The first thing I did was run for the stephascope. Jumping through my ass I listened everywhere. Lots of ticking (loud ticking), but thank God no KNOCKING. The longer it ran the quiter it became.
I'm really looking forward to this just to whacth the peoples faces. Good Luck Allan.
Joe
Allan
Mar 10 2005, 10:43 AM
Okay, no oil at all until the 2nd. I will be brining enough for the first fill and an oil change. 20 - 50 non-detergent.
nebreitling
Mar 10 2005, 12:45 PM
well then, could you pm me with your reasoning? i'm starting up a new motor this weekend and i'd like to know what's up...
n
ArtechnikA
Mar 10 2005, 01:12 PM
it's prety much impossible on a 911/914.6, since the filter is horizontal.
and it doesn't matter anyway, since the oil tank feeds the pressure pump and the filter is just the last stop before the tank on the scavenge side ...
bondo
Mar 10 2005, 02:17 PM
I have a theory. Since the filter is after the oil pump, any oil in there will have to be immediately pushed into the engine. With a fresh rebuild the pump has to be primed, and any work it has to do wile priming itself will make it harder to prime. (like pushing oil through the engine) If you have an empty filter, it can just squirt oil into it while it's priming, which would be less work. That's my theory and I'm sticking to it.
If this theory is right, then an even better solution would be to leave the filter off, and crank until you start making a mess, THEN screw on a filled filter.
