QUOTE (RandyLok @ Mar 10 2005, 10:17 AM) |
If you want to rule out the battery, battery connections, ground strap, solenoid, starter, etc., etc., in less than a minute, do the screwdriver trick: Put the shank of the screwdriver on the main 12v terminal (rests nicely on bolt against nut - see photo), slide the tip forward and tap firmly against the solenoid tab (where large yellow wire connects). If it cranks, pull the screwdriver off and you'll know immediately that you have: 1. A bad ignition switch, or 2. Bad circuit between ignition switch and soleniod (that large yellow wire), perhaps at the seatbelt bypass junk. After that... If it doesn't crank, then it's probably the battery connections (clean battery posts and insides of main terminals), bad ground, bad battery (try a jump start). Is there 12v at the starter? Ok... this is getting long. Keep us posted along the way. |
QUOTE (RandyLok @ Mar 10 2005, 02:17 PM) |
