QUOTE(Mueller @ Nov 3 2015, 02:54 PM)
...am I going to run into the same problem with my crank and rods? (no good bearing choice)
Widely available bearing will work. Don't get mired down in perfection that's unattainable. Obviously there are better and worse bearings. But if you don't want to build a $12,000 engine, accept that the stock bearings are available and will give a
sufficient service life for a street driven car.
Do you even bother with the smaller stroke motors based on the 1.7/1.8 crank and rod?
A small investment can get you a good used 2.0 crank and rods. So it's hard to justify a 66mm stroke crank. But like all engine design, it depends on what you want out of the engine and what your budget is. Generally, spend all your money on heads, and then use what's left on the other parts. Also keep in mind the Cascade Effect®. When one part 'grows', getting bigger and better, the other parts must grow with it.
And if so, I know people build 1911(s?) using the 1.7/1.8 crank and rods, how about a larger diameter piston/cylinder setup?
Keep in mind the Cascade Effect®. If you go over 96mm bore, you really need to take a good look at your head choice. Combustion chamber shape, spark plug location, valve size, port size, etc.
