I'm at my wit's end and need some help solving this problem. 76 914 2.0L starts and runs well cold. RPMs up around 1800 and reacts well to throttle. Once the engine warms up, idle comes down to about 1100 and is fairly steady. However throttle now causes immediate hesitation (bogging) followed by backfire and rough running up to 3000rpm. Over 3000rpm is much better. When I bring the rpm up to 2500 and attempt to hold it there, engine stays at 2500 for a second or two then drops down to 1500 and then goes back up to 2500 and continuously cycles up and down. (I believe vacuum leaks cause the engine to surge UP in rpm then down. This is reverse. It stalls downward then back up) This engine was rebuilt about 10 years ago and has roughly 4000 miles on it.
this is what has been done to date:
1: Replaced the CHT sensor.
2: Replaced all vacuum hoses.
3: Replaced all engine fuel lines.
4: Had injectors cleaned and tested.
5: Had CS valve cleaned and tested.
6: New injector seals.
6: New CS valve gasket
7: New intake manifold gaskets
8: New intake manifold boots
9: New throttle body gasket
10: Removed and inspected plenum. All ok
11: New Throttle positioning switch. Also adjusted.
12: Checked MPS. Both resistances and vacuum good. 20" held no change
13: Checked vacuum on decal valve. 20" held. Opens at 15 or 16
14: Checked Aux Air valve. open when cold and closes after 10 min run time.
15: Checked dwel angle. Good
16: Checked timing. right dead on the notch
17: Checked valve clearance. Good
18: New distributor leads
19: Cleaned distributor rotor and cap. (did not change contacts yet)
20: Checked all resistances at computer terminals and all are good.
21: Checked fuel pressure and steady at 29
22: After engine warm attempted to try different Computer knob positions / bleeder screw settings but have no CO meter. It runs best with computer knob turned all the way Clockwise.
After all this, it still runs the same way. #$^@$&%#%&@$%
My only other thoughts are to change the distributor contacts, check the adv/ret vacuum and perhaps play around with the timing.
I've heard the throttle body could also cause vacuum leaks but not sure how/what to check.
Any help/suggestions would be greatly appreciated (and desperately needed!!)
